DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
functional accuracy
spenceriles
spenceriles
hi guys
could you help with this one how would you check the functional accuracy of an insulation resistance tester
and why is a low value of resistance needed when carring out a cpc test
thanks spenc
Link to comment
Andy™
1: calibration. can be done by using resistors of known values. or a pre made check box (avail on this forum)
2: R2 needs to be as low as possible to allow fuse/mcb to operate
Link to comment
Spence
as andy said you can purchase check box most people sell them RS etc or test from a known source.
In answer to your second question why you need a low value resistance is you will be reading as low as 0.05 ohms
Link to comment
Archived
  • Create New...
