3P, 3-Wire Solar Inverter
dimcha
Oct 26, 2011
Hi all,
Is it possible to connect a 3-phase, 3-wire Solar Inverter (400Vp-p) to LV 400V (4-wire) grid?
Any issue regs this connection?
Any problem with RCD?
Thanks.
If the inverter is just 3 wire it needs just the 3 phase connections.
4 wire 3 phase has a neutral as well.  If the inverter has no neutral, then just connect the 3 phases.
Thanks for the quick response.
The inverter is a 3 phase 3 wire without a neutral.
Could this affect any RCD installed in the circuit?
The inverter is a large scale 600kW. could it be connected to the LV (400V) grid or should be to the 11kV?
11KV RCD... must be fun doing trip times on that...
i hope you disconnect the load before testing it
and you missed a 'p' from the end of your name...
11KV PV inversion - THAT must have a fair sized local isolator........ ;)
just use a normal isolator. surely if it can handle 400v it can manage a little more
but best wrap some extra insulation tape around the wires for a bit extra insulation, and to cover the damaged sheath
