Just a thought - I reckon you could break the light off these and access the plug in part. With a couple of sockets from Maplins and a bit of auto filler you could make up a test jig for Zs at lighting point. Must give it a try!As the title really, went to B&Q and they were doing energy saving lamps bayonet fitting 11w for 10p, maybe worth people stocking up.
Yeah - thay're the ones - seem vastly overpriced to me!
I dont quite understand how these fittings can read R1+R2 and Zs because they only make contact with live and neutral or am i just being
You have to stick your earth cable on the metal fitting or earth connection to do your tests but they are one of the best things to use on lighting if you do a lot of testing.I dont quite understand how these fittings can read R1+R2 and Zs because they only make contact with live and neutral or am i just beingTHICK?
Ahh i see thanks batty.You have to stick your earth cable on the metal fitting or earth connection to do your tests but they are one of the best things to use on lighting if you do a lot of testing.
you said it not us :^O :^O :coat ] :good night:I dont quite understand how these fittings can read R1+R2 and Zs because they only make contact with live and neutral or am i just beingTHICK?
Thats a good idea I may have a go at that, if anyone else does in the mean time can they post some pictures on here.Just a thought - I reckon you could break the light off these and access the plug in part. With a couple of sockets from Maplins and a bit of auto filler you could make up a test jig for Zs at lighting point. Must give it a try!
unfortunately, this is a very common sight when changing lights / PIRs/fault finding.....Frankly I think its easier if you wire this way, testing is sooo much quickerhttp://i645.photobucket.com/albums/uu178/robojin/IMG_2870a.jpg
