Anyone got experience of supply/ protective device regs for domestic sprinkler in Wales/England
company who supplied and are commissing are useless.
Bs 9251 ref is quoting a bs88 type fuse seperate supply before main consumer unit which is not prob but no RCD protection?
control box for fire pump label states no fused spurs or mcbs.
Anyone like give it a sab as its looking like i need an isolator which will take a small bs88 motor rated fuse,but will need a 100amp isolator for split supply tails 25mm.
motor is max 22Amp on start up label states 10-16amp max protective device.
this system has a 2000litre tank outside which also houses controls and pump.
flow switch on sprinkler pipe in the property has had connected to activate all smoke /heat CO alarms on activation.
