Help finding a 'drop down' outdoor wall light?
aidanb19
Nov 2, 2008
80
Anyone know of any outdoor wall lights similar to THIS but with a PIR?
Yes I know the light sort of blocks where the PIR would be, but hope i'm destined for a separate one
Concur with t'others..
fit a standalone PIR somewhere adjacent to the lamp!
But I would fit a Black one outside.. not a white one...
Don't show up the mess so much when it gets grubby!
was hoping to avoid that, and not fit a normal PIR lantern upside down! Standalone PIRs are ugly, also it'll be going in my porch, which will eventually become the 'reception' area.
Be handy for alerting you when low flying aircraft are passing!
I've not looked too hard for one tbh, but should be easy enough to make one, either find a base that's the same\similar as you light with the PIR built in or make one. If the lantern is just 1 piece of metal screwed into a flat piece of metal then I'm sure it will quite happily reside in any base from any lantern.
