Q1. The current in a coil changes from 5 amperes to 2 amperes in 50mS and induces a voltage of 30v into the coil. Calculate the value of the inductance of the coil?
Q2. Calculate the power dissipated by resistor 2 in the circuit here
(R1 = 5ohms, R2= 10ohms, supply voltage = 20v)
Q3. Calculate the synchronous speed of the rotating magnetic field in a 4-pole synchronous motor?
Q4. An inductive load with 10 ohms inductive reactance is connected to a 100v 50 Hz AC supply. Calculate the power dissipated in the circuit (ignoring any conductor resistance.)
Q5. Calculate the inductive reactance of a coil with inductance of 0.1H, connected to a 50Hz AC supply.
Thanks for any help.
