Help with questions please
jonnymc11
Jun 3, 2008
88
Q1. The current in a coil changes from 5 amperes to 2 amperes in 50mS and induces a voltage of 30v into the coil. Calculate the value of the inductance of the coil?
Q2. Calculate the power dissipated by resistor 2 in the circuit here
(R1 = 5ohms, R2= 10ohms, supply voltage = 20v)
Q3. Calculate the synchronous speed of the rotating magnetic field in a 4-pole synchronous motor?
Q4. An inductive load with 10 ohms inductive reactance is connected to a 100v 50 Hz AC supply. Calculate the power dissipated in the circuit (ignoring any conductor resistance.)
Q5. Calculate the inductive reactance of a coil with inductance of 0.1H, connected to a 50Hz AC supply.
Thanks for any help.
Q1. The current in a coil changes from 5 amperes to 2 amperes in 50mS and induces a voltage of 30v into the coil. Calculate the value of the inductance of the coil?Inductance = induced voltage x time / change in current
L = 30 x 0.05 / 3
L = 0.5 H (or 500 mH)
Depends...
If in series then add resistors together ( giving Rt) and divide answer into voltage, this gives your current = 1.333 A
P = I x I x R
So P = 1.333 x 1.333 x 10 = 17.76 W
If in parallel then divide voltage by R2 = 20 / 10 = 2 Amps
Then multiply this by the voltage = 40 W
Motors aren't my strong point but I think we need the frequency for this calc.
If we assume 50 Hz then:
Synchronous speed = frequency / pole pairs
Synchronous speed = 50 / 2 = 25 revs per second
This could be a trick question - with a purely inductive load there won't be any power dissipated - so answer 0 Watts
Inductive Reactance = 2 x pi x frequency x inductance
Inductive Reactance = 2 x 3.142 x 50 x 0.1 = 31.42 ohms
I think they're right:good luck:
Thats very useful mate, thank you very much, appreciated!
yeah the resistor one was in series.
A circuit connects a 28.8 ohm resistor and a capacitor with capacitive reactance of 38.4 ohms. Calculate the total impedance of the circuit
38 ohms
24 ohms
48 ohms
44 ohms
(Z=?)
thats what i tried, but the answe doesnt match dto the 4 given on swindon massive, which is in my post.
got 48ohms now :)
its how you put it down on the calc - is the problem
had to do: Z = √( 28.4
Q1. The current in a coil changes from 5 amperes to 2 amperes in 50mS and induces a voltage of 30v into the coil. Calculate the value of the inductance of the coil?Q2. Calculate the power dissipated by resistor 2 in the circuit here
I remember having to do this in my online exams for my Level3 2330, i HATED this paper. I failed it 4 times before I finally got it, they ask you to remember so many equations and sequences for every different unit!! Hope it goes ok for you though!!!
A circuit connects a 28.8 ohm resistor and a capacitor with capacitive reactance of 38.4 ohms. Calculate the total impedance of the circuit38 ohms
24 ohms
48 ohms
44 ohms
(Z=?)
:) 28.8 not 28.4 that everyone is working to, answer exactly 48
(R1 = 5, R2= 10, supply voltage = 20v) (series)
17.8 watts
19.9 watts
10 watts
14.4 watts
Q2. Calculate the power dissipated by resistor 2 in the circuit here(R1 = 5, R2= 10, supply voltage = 20v) (series)
17.8 watts
19.9 watts
10 watts
14.4 watts
Hi jonnymc11,
Something wrong with my calculator in my post above - all the figures and formulas for this question are right.....but the answer is wrong!!! :eek:
It's A, by the way, 17.8 watts.
I've altered it in my first post now:|
cheers mate, also:
A circuit consisting of an inductance of 0.35H connected to a 50Hz has an inductive reactance of:
a) 9.1 mΩ B) 0.09 Ω c) 109.9 Ω d) 1.099 kΩ
im getting 0.09, is there a power to go with the inductance?
as im doing:
1 / 2 x 3.142 x 50 x .35
= 0.009
cheers mate, also:A circuit consisting of an inductance of 0.35H connected to a 50Hz has an inductive reactance of:
as im doing:
= 0.009
If it had been a capacitor the calculation would be
1/ (2*PI*50*0,35)
Brackets important again:)
