How to convert 230V to 400V
blackbolek
Feb 22, 2016
4
Hi everyone,
I want to install 400V HPS light (600W) on site without three phase supply.
I looked at step-up transformers and various inverters but I couldn't find one which takes 230V a.c. and gives 400V a.c. and is rated at minimum 0.6kW.
What I have found is this: http://www.amazon.co.uk/CLARKE-PHASE-CHANGER-2HP-Amps/dp/B006YLZFWW/ref=sr_1_2?ie=UTF8&qid=1456166780&sr=8-2&keywords=230+to+400v+converter, however I would prefer something slightly simpler (without 3ph socket, voltage indicator and switches) preferably something I could mount in the box on the wall.
Could anybody recommend piece of equipment which would do the job?
Hi everyone,
2x 230v 400w HPS lamps. Far cheaper than that piece of kit.
It's a supplementary growing light for the plants in the greenhouse.
OK. Just for my curiosity (without any suggestions that it's easier to swap 400V light for 230V one), can anyone answer the original question?
Trafford transformers
ask them to build you a 230/400 transformer to give min .6kVA
will it be cheap?
will it courgette
Hi Blackbolek,
Can i tell you that the piece of equipment you have linked to ABSOLUTELY DEFINITELY WILL NOT WORK for what you want to do...
It is a contraption composed of capacitors to enable you to run 3 phase motors [after a fashion, glad they are not my motors] from a single phase supply..
what you need is something like...
http://www.airlinktransformers.com/chassis_mounting_toroidal_transformers/chassis_mounting_autowound_toroidal_transformers/AT01004/
Hope you know what you are doing though.....
john...
John, I just read the specs of your link and it beats mine hands down, it comes with 2x dish washers
Hi Blackbolek,
john...
Thank you John. This is exactly what I was looking for. Cheers.
