MEM 2000 MCBS
i am after 40amp for a shed/workshop supply from the house board
i can go with 32amp if need be
but i know he will want to expand in the future...
cheers Andy
i can get the 32 from ebay no probs just the 40 i would like
hi i have the white ones in stock, but not the 40 amp
however if you compare it to the memra 2000 range it is the same so any wholesaler can get it for you.
regards andrew crosse @ mcbfinder cheaper and more range than thefusecompany!!! :)
hi i have the white ones in stock, but not the 40 amphowever if you compare it to the memra 2000 range it is the same so any wholesaler can get it for you.
ROTFWL ROTFWL ROTFWL ROTFWL ROTFWL ROTFWL ROTFWL
got the 40amp from the fuse company !!!!!!
this time they had more range
but will use your site as first call next time.
i thought mem 2000 mcbs were still available from wholsalers, if this isnot the case then i will start to carry a larger stock.
What's so special about that MCB?
I could be wrong, but to me it looks to be a standard MCB like any Wylex one, which are readilly available.
Have you actually tried a Wlex MCB in that CU?
AS I say it could be the input terminals are at an odd height, but worth a try.
