Myson Y plan problem
GreekIslandLover
Oct 18, 2008
118
I didn't notice this section of the forum!! I do have a problem I'd really appreciate some help on.
Ok - Myson floor standing lump-of-cast-iron boiler approx 20 years old. Originally had internal mechanical timer. This was disconnected a few years back and replaced with a Lifestyle programmer by our local (trusted) heating engineer. Been working OK for a while.
We got it serviced recently, and asked them to look at the three port valve as it was only supplying hot water, and you had to move the valve to manual to get heating. Unfortunately, because the thing is in a difficult to get to place the guy couldn't do anything with it at the time.
I took it into my own hands to dismantle the cupboard and replace the head of the valve myself. Have done it before, but didn't fancy doing it myself this time. Took the front off the boiler to wire in the thing, and noticed all of the wiring was brittle and the chock strip connectors were all very brittle and fell apart. Decided to get a proper wiring centre and relocate all of the cables to that, leaving just the switched supply to the boiler only in it.
I did that last night, and turned it on. As far as I can see, the electrics are working ok, but after a short while there was a noise in the loft, and the heating was boiling up the overflow into the header tank. Turned it off PDQ!
Where I THINK I might have gone wrong is that the boiler has a thermostat on it. I couldn't find a wiring diagram for it online, so decided to leave it out. I know - dumb! Would I be right in assuming that to connect this stat, all that is required will be to have the switched live coming from the wiring centre on one terminal, and the other terminal of the stat to the live to the boiler? It's a mechanical dial that has numbers 1 - 8 and off, with a thickish wire running into the boiler cast iron lump. I'm guessing that without the stat shutting the boiler off it's gonna behave like a kettle.
Also, the old wiring of the controller didn't have a cable from the hot water off terminal of the controller to the tank stat / valve. It's used L and N plus HW and heating on only. I guess the tank stat provides the hot water off signal to the valve. Is there a reason they might not have used this cable? I have wired it in as I followed the honeywell y plan diagram.
Many thanks!
Edit - the boiler is a Myson Marathon 800b
Not to worry - found a complete installation manual including wiring diags online. The stat is fitted in series as above.
