Outside Lights!!!!!!!
hoppy
Jun 28, 2009
81
Hi, I am installing 2 outside lights, the customer wants the two lights linked, so eithern PIR turns both lights on. I know I have to check if the PIRS can work together.
I am trying to get my head around how to wire them, as all of the outside lights i have wired in the past only have a live, neutral & earth terminal. Surely a 4th terminal would be needed for a switch live, so i could have a loop terminal.
Could someone advise me on how they would do it, I have a few ideas but would like some experienced advice. Pray
Thanks Guys
Craig
youll find in just about every light fitting, there are 4 terminals, the 4th where the sw. live from PIR connects to live to lamp. wire 3core flex to light 1, and 4 core flex to light 2, and connec the sw. lives together
if u are using one PIR and two lights, wire the PIR up as normal to one light, and install a link to the next light...
job done.......
I would disagree with this a lot of the cheap pir lights do not have the swl connection.
Batty
