pir wiring
L-E_Fault
Mar 23, 2009
423
Has anybody got a wiring diagram for pir's.I have to change one way switched lights looped in at the light to be controlled by a pir.
Ta Tim
If you meen you are replacing the one way light switch operation to a PIR controller then a three core run from the light to the controller and then as above stated --permanent live in.......neutral in .....and switched live out....... cpc usually parked at relevant location at controller. & Isolate existing Switch drop wiring .
heres a paint job diagram hope its of use.
