This mornings little job, customer purchased all materials & had already run the T/E internaly through the loft & the swa outside but couldnt work out how to do the rest, so I supplied labour only to teminate test & certificate/notify the connection of a small submain to an external cu & put power into a globe outbuilding.
This is the building
http://i83.photobucket.com/albums/j293/gazjothomas/IMG-20120721-00045.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/IMG-20120721-00049.jpg
Last one shows location of the cu to the left of the decking.
http://i83.photobucket.com/albums/j293/gazjothomas/IMG-20120721-00050.jpg
TT'd the external cu..
http://i83.photobucket.com/albums/j293/gazjothomas/IMG-20120721-00048.jpg
CU located on the decking as requested, not what I wanted to do but heyho.
http://i83.photobucket.com/albums/j293/gazjothomas/IMG-20120721-00047.jpg
RCD main switch on external cu, Pirahna Nuts used to keep IP rating of enclosure.
http://i83.photobucket.com/albums/j293/gazjothomas/IMG-20120721-00046.jpg
(yes I was chatting & not concertrating & lopped off the circuit cpc to short hence the doubled up 2.5mm......no 4mm on the van)
Joint of swa to T/E wiska box used to enclose the joints (put in last Dec)
http://i83.photobucket.com/albums/j293/gazjothomas/IMG-20120721-00044.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/IMG-20120721-00043.jpg
The FP drops to a masterseal socket on the patio below, this is a 16amp radial put in last Dec.
