Revved Up Sparky
Hi guys, happy new year to you all !.
I'm doing a mains change next week on a TT installation. The meter tails enter a 100mA RCD from which a 16mm T&E submain runs to the consumer unit.
I want to fit a dual RCD consumer unit in line with 17th edition regs.
I also want the change the main RCD from 100mA to 30mA in order to ensure the submain feeder also has the 30mA RCD protection required.
BUT !.... this creates a discrimination problem. If any circuit on either side of the consumer unit has an earth fault then the main RCD will probably trip before either of the dual RCDs on the consumer unit trip.
It would be very difficult to extend all the final circuits and position the consumer unit where the cutout is so what should I do ? How can I provide 30mA RCD protection to both submain cable and final circuits whilst also having a correctly functioning dual RCD consumer unit where the main RCD feeding the submain will not trip before either of the dual RCDs ?
Many thanks in advance.
