but you are extending it ?No need for RCD as you are not altering the existing CIRCUIT.
Only if the new cables are burried in a wall less than 50mm deep.but you are extending it ?which i was lead to believe required rcd ?
just been on their web site ... in downloads there is a pdf on thisi've asked the local field engineer for Napit on this subjust and his answer was in this instance you only needed to rcd the circuit if you introduced a new switch drop and that switch cable was buried less then 50mmpersonally i wouldn't bother with the rcd fcu or a rcbo
How can you be so sure?No need for RCD in my opinion.
