Reynolds Boughton rb44
Paul1W
Apr 20, 2020
Hey all, just joined the site so apologies if I get some stuff wrong!
I have an ex army truck which is based on a Renault Dodge 50 but was modified for the MOD by Reynolds Boughton in the early 90s.
It failed it's not this year as the headlights weren't bright enough to give a focused beam.
Turns out the dipped headlights are only worked on a dip dim 5% setting but I cannot work out why.
I am hoping someone will know what causes this and how to fix it.
Thanks in advance for any advice!
If you only have dim dip headlights working then it sounds like you have a faulty headlight switch or relay
Check that all earth connections are sound and the dim dip relay(If fitted) is functioning correctly.
