Hi, got an open circuit on the nuetrals of my socket circuit (line and cpc OK) have checked socket outlets cant find a loose/ broken connections, whats the method of locating this fault. (adult trainee and have test instuments)thanks in advance
Hello Mouse...
Adding a bit more thought to the other guys posts you need to be thinking....
- Is it 'open circuit' or a 'High resistance'?
- Is it 'One' Neutral break or 'Two (or more)' Neutral breaks?
If it was me I would do the following
1/ Make sure EVERYTHING on the circuit is unplugged disconnected & switched off to avoid any false - misleading readings.
2/ Disconnect both T&E ends of ring from CU
3/ Do an Insulation resistance test @ 250v across L-E, N-E, L-N at both ends of the rings T&E's just to check all is unplugged & disconnected.
4/ Do an insulation resistance test round the broken ring leg... i.e. 'N' to 'N' on each of the T&E's to see if it is absolutely open circuit or just very high resistance.
5/ If 4 is showing a high resistance reading, double check your Live & Earth continuity resistance readings (the know good legs) and calculate an approx length using the ohms per meter table on page 166 of OSG. to check if both the existing continuity reading are approx right or is one of these also a bit to high.. (could be an indication of dodgy joint somewhere)
6/ To establish if you are looking for One Neutral break or Two (or more) Neutral breaks...
In a similar fashion to what Ian said Join 'N' & 'E' on one of the T&E ring ends....
But also join 'L' & 'N' together on the other T&E ring end. (Wago lever connectors are good or that bit
7/ Go around all of the socket / accessory outlets and take a continuity reading between 'L' - 'N' then 'N' - 'E'. Every outlet should have either a 'L'-'N' continuity for a 'N'-'E' continuity.
8/ If an outlet position has neither 'L'-'N' OR 'N'-'E' continuity then there is probably two breaks in the N ring.
9/ If every outlet does have a continuity between either 'L'-'N' OR 'N'-'E' then the fault is somewhere between the two outlets with the highest continuity readings.
Guinness
