Seplos bms and lifepo4 battery cells on solis inverter setting
Duffman
Oct 16, 2023
3
Irrland
Hi what battery setting do you have on the inverter and what inverter setting do you have set on the Seplos BMS?
Split from hi-jacked thread
Make sure the seplos bms programme you use on rs485 is on version 20.1.19 or higher not 20.1.18 also check the siftware verwion in your solis inverter as newer siftware is v17. Something
Hi Badger, thank you for the advice. I have the new Seplos BMS V3 200ah. I have just charged all the battery cells for the first time and am about to connect them all up to a 4ah Neey active balancer and the Seplos BMS. Do I use the CAN port on the BMS to connect to the computer or do I use RS485 port 1 to connect to the computer. I also have the rj45 to usb connector That came with the BMS, I believe this allows me to use a normal cat5 network cable to connect the BMS to the computer.
