Solarexploits
Hi, I'm intending to do a DIY install of a small solar system, grid tied, 3.6kW. I obviously need a sparky to do the sign off & would like to discuss the job with him in the first place to ensure we are doing everything "by the book".
I can't find anywhere exactly what qualification is needed for the sign off & obviously don't want someone without the correct qualifications
Couple of further Q's can you have a larger array installed but have an inverter (obviously on the ENS G98 list) that has a limitation on output, or indeed can set output to zero, don't feel it's worth the hassle & additional expense to go the MCS route to get paid for exports
Also, can anyone confirm that he will only be concerned with the electrical side of the installation, not the physical mounting of the panels as we'll be using some non standard home made mounts on a flat roof & obviously don't want to create an unnecessary problem
If anyone is local to me in Essex & wants to volunteer services at a fair price by all means get in touch
