Elekk,
IF you are merely switchitn lives, run the lives through the load connections.
IF you are using a "normal" light switch to control the contactors, you don't need a retain circuit, thus wire all the A2's in parallel to N.
Wire the A1's in parallel, with the light switch in series with the supply to one of them
HTH
