DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Best Way To Work Out 2 Bed Flats Consumption
Cj01296
Question
24 answers to this question
Never fit dual rcd boards, hi integrity or RCBO for me
Link to comment
Two threads of near identical topic merged.  Please do not start a new thread each day when you already have a very similar topic already on the go.
Link to comment
whack in 600A 3 phase should cover it
Link to comment
Surely no RCD would be more convenient for disruption :innocent
Link to comment
Well I think you're right  Pewt,  and if we get rid of  emceebeez too ..........even better. :innocent
Link to comment
Two members of near identical name and posting questions on near identical topics merged.  One thread and one member name should be quite sufficient for our other members to find and reply to your questions thank you.
Link to comment
You get what the DNO say don't you?
Buy what you think you need depends a LOT on how you heat the rooms and hot water etc.
Link to comment
Gosh.....so many questions.... so little detail.....
Link to comment
Best way to work out 2 bed flats consumption For the right size incomer. Thanks
ask someone competent would be a good start
Link to comment
Your having a giraffe aren't you, you need to give more details of what will be connected?
Link to comment
Two two bed flats? or one two bed flat?
Link to comment
A proper electrician should be able to tell you that......
Link to comment
If you calculate your total loads allowing for diversity that should give you expected max consumption and thus incomer required. Alternatively see what the DNO give you. Or are you filing out an application for a new supply and you are asked to state your max load?
Link to comment
Easiest way to calculate max demand with diversity, eg do you add showers and equipment using power for short amount of time? Thank you
Link to comment
What's the best way to work out max demand and divercity
Eg do I included a shower as its only running for a matter of minutes
Link to comment
Do you think that an electric shower running at 40 odd Amps has much of an effect on MAXIMUM demand?
Link to comment
What I'm asking obviously you will not be adding everything together as that would be 100%. Just trying to find out the easiest way to see what kind of cable I will need to supply the flats
Link to comment
What is the incoming supply available? Does it need upgrading?
So many questions... so little detail
Link to comment
Perhaps you can give us some information as to what you think you should be doing to calculate demand and therefore cable size, it would give you more confidence in your abilities if what you show us is not too far off the mark, you will therefore perhaps gain some valuable knowledge thus experience to make you a better spark. :)
Link to comment
Hi I'm wiring a flat with
1 x lighting
2 x ring
2 x heating ring
1 x hob
1x oven
Just would like to know if you would dual rcd the board or use 1 rcd. Thanks
Link to comment
RCBOs - worth the little extra
Dual RCD is minimum requirement to meet todays regs
Link to comment
seeing as you have 2 ring rings the a dual arseedee may be just the ticket ;)
Although as above RCBO's would be the best solution.
Link to comment
I would NEVER use a dual RCD board
T,he regs say ccts to be designed to minimise inconvenience/disruption.....2 RCDs does NOT minimise inconvenience, it merely halves it
RCBOs all the way for me...end of
Link to comment
Clifford ,  one arseedee doesn't really comply with the "Inconvenience" factor when tripping .
As the Kerch says  , arseybeehoes are the better option .     I use dual boards  because my loop tester knocks them out but not the "proper" arseydees .
Link to comment
Archived
  • Create New...
