DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Putting cable through walls
mistymoo
Question
I'd appreciate some advice please...
If I need to take cable through an external wall to outside (say for an outside light or to take power to a shed) what do I fill the hole with around the cable to make sure fire regs etc are met? I suppose it depends on what the building is made out of? There's probably a really obvious section in a book somewhere that I've missed reading but if you guys have got any experiences of this you could share that would be even better.
Thanks,
M
Link to comment
12 answers to this question
I wouldn't worry about fire regs to the outside but more about damp
fill the hole with silicon and drill up hill from outside so no water can track across cable
Link to comment
As above , drill slightly up and seal with silicon .
Link to comment
drill downwards to outside, put some silicone into gap. brown silicone matches best
Link to comment
I found it on pg 107 in the regs book, well the bit about fire regs anyway. Thanks. I used some silcone stuff but it was way high up on the building so no one will see it anyway!
Link to comment
no one mentiond sleeve ? we sleeve any cables through walls usually using plastic conduit. surely i am not the only 1 who does this .. :) hehe
Link to comment
looks like it!
Link to comment
inside to out
small drill bit progressing larger to the required size
tape on drill bit to roughly depth of wall slow down when near to outside wall
prevents large ''blowing'' of brick
Link to comment
The whole submain was in conduit. I was in a loft on a really warm day putting cable through conduit to avoid rodent damage. However I am not moaning as it beats the pants off the office I used to work in.
The conduit was not an exact fit for the hole in the wall hence the q. Thanks for your answers.
M
Link to comment
Archived
  • Create New...
