DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
need advice please
chrishornby
Question
Hello again...
I'm fitting a sound limiter which has a contactor which cuts the power to the sound rig. The rig is on a 60A mcb, straight from the board to a commando socket in 16mm. Usually this contactor cuts power to sockets which is fine but in this case I'm confused.
Any suggestions would be much appreciated.
Link to comment
7 answers to this question
then put contactor on feed cable. but are you sure its a good idea to put it on the feed? id imagine the electronics inside wont like being turned off like that often
Link to comment
Sorry Andy, didn't explain properly, just re-read. Sound limiter comes with a pre-assembled contactor with the electronics in but it is 32amp normally fine when i just need to control the sockets. Obviously much different now with the 60A mcb and 16mm cable.
Can you help?
Link to comment
then mod it with either a larger contactor or use that contactor to feed a larger contactor in the 16mm
Link to comment
ok, did think of changing the contactor but this unit has a 32amp fuse(looks like a mcb) next to the contactor. Do I need a fuse for the 60amp contactor and secondly will 16mm cable fit into a 60amp contactor. It won't in the contactor unit supplied.
Link to comment
if you have an external contactor you do not feed to put a fuse on the incoming cable. depends on the contactor, some will take a 16mm
Link to comment
Cool, thanks.I'll probably modify then. The one I'm looking at takes upto 25mm. Does 4 pole make a difference, can I use it as a 2 pole?
Link to comment
you can link 2 terminals together, but if the contactor is rated to the current, its no real benefit
Link to comment
Archived
  • Create New...
