no good if you dont read the instructions eitherAll hager bs numbers are on the info sheet that comes with the DB, no use if you didnt fit it I know but for future ref.
its for when it doesnt work and all else fails and youve already wasted a minimum of 2 hours, then you can RTFM and be done in 5 minsInstructions what are they.
even worse if you cant read;\no good if you dont read the instructions either
