DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
My consumer unit...
AAAMUSEMENTS
I've seen worse..........
:D
Love the wood
Link to comment
Classy or what... :o
At least you have got some buttons and switches when the fuse trips!
Other than that......
WTF..... where are the lights????:o?:|
1 x 32A (button)
2 x 32A (switch)
1 x 16A (switch)
1 x 20A (switch)
1 x 20A (button).....? or is the yellow an OFF colour white (5A)
Link to comment
That 16 amp has all the lighting circuits. It originally had a 5 amp in it but that used to go if too many lights were on.
The yellow is a 20 amp, for the immersion heater.
Link to comment
mmmm
interesting.................
:o
Link to comment
oh vicar! innuendo....
:o
isn't that what you GF says???:OBlushing]:)]:)]:)
only on special occasions......................
Link to comment
GULP. Hope its not 1.0mm cable or worse then.
Link to comment
only on special location's......................
ohhh!!!!!:o:O:p:pBlushingBlushingO)
:^O:^O:^O
ROTFWLROTFWLROTFWLROTFWLROTFWL
Link to comment
:^O:^O:^O
PMSL ROTFWL
Yours has had enough use. Let us 'young uns' at it
:D
Link to comment
That doesn't sound good..:(
assuming you have 1.0m cable on your lighting circuit...
which is quite likely,
depending upon installation methods the cable should only carry around 10A -11A ish!
so MAX fuse rating would be 10A...
with a 16A, in the event of a fault or overload it is possible that the cable could melt before the fuse trips!!!
you should seriously consider getting a formal inspection carried out on your installation to double check all fuse ratings, cable sizes, cable condition, earthing, connected loads, max demand etc..
my gut feeling is that CU has overrun its best-before date!
and could probably benefit from an upgrade!:|
Link to comment
2.5 mm I think.
from the picture..
it would look IMHO to be more 1.0mm ish..
i.e.
far right 32A is probably 1 x 4.0mm or 6.00m
next 32A looks like 3 x 2.5mm
then the 16A looks like 3 x 1.0mm
Link to comment
from the picture..
i.e.
Yes, most likely. I was referring to the immersion cable being 2.5mm, the lighting is almost certainly 1mm.
I am well aware the whole installation is extremely dodgy and needs to be changed, we have been trying to find an electrician willing to do it for the last 3 years.
I have made a post about it on here somewhere...
The services are not bonded at all. And the main earth from next to the company fuse to the CU is less than 10mm cable by the look of it. And that was presumably put in by EME.
Link to comment
Where about's are you?
Link to comment
  • 1 month later...
love the bare busbar too under the main switch. Good old Wylex boards...
Link to comment
But its not just Wylex all the older boards have live accessible parts thats how they where made.
Batty
Link to comment
Batty
Indeed, the logic at the time presumably being: "It was on? And you still stuck your fingers in it??"
ROTFWL
Link to comment
Have you managed to find a spark that can do it for you now, Mate?
Nope, got a couple of tentative offers though.
Been in the loft since we had the new flue put in and decided that the upstairs needs a rewire anyway... :|
Link to comment
  • 1 month later...
I`d come & do it for you mate......
Travel cost from here could be a bit heavy though................:)
But yeah - I`ll do it.
Link to comment
Archived
  • Create New...
