DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
ring spur
tom1
Question
i cooked up a new question. spur off socket on the ring to a dule back box containing 2 switch fcu
is that wrong? the maths checks out
Link to comment
13 answers to this question
whats the reason behind it all?
Link to comment
washer and tumble dryer under worktop putting 2 fcu above. there is only 1 socket which needs to be kept.
i will find a way round it
Link to comment
Andy™
the way it was looking was a spur from a spur, which is un acceptable, however what got me thinking as its two 13amp fcu, its the same as 1 double socket, 26 amps on 27 amp cable, not that it would pull that much anyway
a double socket is only rated 13A between both outlets. check the back of just about any socket and it will say '13A'
Link to comment
isn't this socket on the ring? Then just add both fused spurs onto the ring?
Link to comment
Andy™
you shouldnt take 2 spurs from same point. although you could extend the ring to include the 2 SFCU. or take a spur from 2 different sockets
Link to comment
I meant it as in, adding each fused spur plate onto the ring circuit, not spuring off the same socket if you get me.
So each fused spur is on the ring final circuit.
Link to comment
Andy™
that would be the best method
Link to comment
thats what i will do, thanks for the advise, i over think things sometimes and should keep it simple
Link to comment
Not sure i'd be keen on putting a washer and drier on a spur bearing mind they're both high demand appliances which are often on together. On 2.5mm you could potentially get very close to max capacity of the cable.
Link to comment
Andy™
as long as there not a spur from spur, then nothing wrong
Link to comment
flyingspark
Surely if its a spur from a ring, then in your example, the only way to connect both fcu's would mean that it would then be a spur from a spur.
So, starting with the socket connected as part of a ring, spurred to the first fcu, from first fcu on to another fcu (regardless of its proximity to the first fcu) would be a spur from a spur, and therefore un acceptable?
Link to comment
Andy™
not always. if you installing as part of a re-wire or new circuit, you could easily install a dual 1g box, have both FCU's on the ring
Link to comment
Link to comment
Archived
  • Create New...
