DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Certs / Forms for NIC assessment
Lillpete
I'm going to be completing a ccu upgrade on Friday which I will use for my NIC assessment, I have some Kewtech installation Certs but looking at them they are missing a number of boxes compared to the NIC ones I used to fill out (whilst employed) I'm a bit concerned that the assessor won't like them?? I'm also panicking slightly about what charts and stickers to use I've got two colour and RCD stickers as well as "next periodic due" ready and safety earth for met anything else to consider.
It's TNS and there are 10mm bonds already in place :D
Also what do you think, is it acceptable to have lights and sockets in a lean to kitchen porchy type area which look hardwired to actually be plugged into a socket in the next room??
If Kewtech Certs are no good, is there anywhere I could download a better form or do they have to be carbon copy??
Link to comment
As long as the certificates you use are to the template given on the iee forms, you are ok to use them.
Your assessor will not be able to give you any detailed tips on filling out any forms other than the official NICEIC forms.
They must be 17th edition and not 16th and filled in as accurately as possible.With no blank boxes, always put n/a in any box not required.
Link to comment
Trouble is I'm booked in for 8am on Friday, so anything in the post is too late now although I could fill out the cert later I guess, Thanks for the info
Link to comment
Here,
download and use these, there's now way they can pull you up for using them..
The link for the download is on the right hand side near the top!
http://www.theiet.org/publishing/wiring-regulations/forms/
Just remember to give each one a unique serial number and keep a record
Link to comment
Thanks NozSparks, the good news is that the form I just downloaded is very similar to the Kewtech ones I have so should fine with them I think :-)
Link to comment
The NIC used to send out some sample certs with your "application welcome pack thing" whatever they call it.....
the stuff where the tell you all you need to know about your forthcoming assesment....
it included some small pad's with about 10 EIC. 10 MWC, & 10 Smoke Al certs.
So you would have stuff to be able to fill in, in the style they prefer.
As GH says providing forms are to the model in BS7671... there is nothing they can say...
But if you do get some green NIC ones.. it would carry a few more brownie points on assessment day.
If I were you I would go on there On-line shop & order some Certs & any other stickers you need.!;)
Link to comment
i was told they dont send them out anymore you have to buy your own. try these there nic eic ones but cheaper than getting them direct(only books of 10 but WHEN you are accepted you'll get the purple/red ones anyway). will give you a good start on asssesment day
http://www.tlc-direct.co.uk/Products/BK17D10.html
http://www.tlc-direct.co.uk/Products/BK17M10.html
hth waye
Link to comment
hth waye
:_|:_|:_|
darn Tight Wads!!!!:(:_|:_|
when I were a lad they give em out free!!!!Blushing:|;\:D
Link to comment
Archived
  • Create New...
