samcassers
Hi there,
I have been reading my meter for the past 12 months or so, and the meter reading always seemed high.
The flat is a very small 1 bed with nothing out of the ordinary and seems to be using about 30kwh per day, which I thought was high so I decided to investigate.
There are 3 meters in the flat, and 3 flats in total in the building.
2 of the meters are pay as you go (see image below) and the other (my meter) is a standard one. As you can see from the image - the PAYG meter on the left has stayed at £26.90 for over a year.
I turned of the power by the flip switch (all power in the flat was off) but my meter was still going up slowly. I could hear the suspected flat had the TV on and lights were on. After half an hour the PAYG meter hadn't gone down even by a penny but mine had gone up by 1 kwh (even though the power was turned off by the mains to my flat).
Is it possible that my neighbor's flat is running off my meter and I am paying for both hers and my bills? If so, what steps should I take to fix this issue?
Thanks,
Sam
Thanks,
Sam
