Hi All
I have replaced the bulbs in our kitchen halogen spots with LED bulbs (6 overhead spots). What I didn't realise was that the existing dimmer switch will no longer dim as the power draw from the LEDs is so much lower.
It seems like I have 2 options (1) to replace the double dimmer switch with an LED compatible dimmer switch cost c. £40 or (2) replace the dimmer switch module in the existing dimmer cost c. £12 (or £24 if I need 2 as the switch is a double dimmer for 2 sets of lights?)
Question: how hard is it to replace a dimmer switch module? Do I need 2 for a double dimmer? If I have to get an electrician to do this I suspect it will be cheaper just to replace the dimmer switch for £40. Am I missing anything?
Thanks for help
Thanks for help
