- Joined
- Nov 28, 2009
- Messages
- 14,674
- Reaction score
- 829
Okay, the next "problem"
I was sent do do a simple job. a cable in the loft had got trapped by the loft hatch (because the original installer didn't clip any cables) and it has cut through the outer sheath.
It was a 3 core & earth cable, probably the landing light strapper, or possibly a feed to the bathroom fan. At this point I didn't bother to identify which circuit it was.
I was in the loft with a lead lamp plugged into a socket on the landing.
As it was accessible my plan was to just repair the damage by terminating it into a junction box and clip the cables so it wouldn't happen again.
So I went downstairs to the one and only CU, turned off the main switch and went back upstairs.
As expected the lead lamp had gone out, so I planned to make the repair by the light of my head torch.
As I closed my cutters around the damaged cable to cut it, my lead lamp came back on.
How and why? and what was the problem?
What tests did I do to arrive at the conclusion?
P.S this was discussed once before. If you remember it, don't take part, leave if for those that have not heard of it before, and don't cheat by searching for it.
