Quick one to see if anyone has any further thoughts about it...
Firm I work for is doing the electrics for a new all electric kitchen in a commerial building, existing supply is maxed out, so the plan from the main contractor along with the DNO (the DNO themselves seem happy enough about this, which I did wonder when it was looking like it would get suggested), is to bring another feed from the local 11kv tx on the site boundry into the outside switchroom, where it will feed a separte head and CT chamer, this feed is to go to a switchfuse which will then feed the submain into the kitchen area
There was some debate about the suitability of this, my opinion is that its not that uncommon in larger buildings, but some issues to be addressed; both supplies will have to be tied into the same earth bar... DNO needs to be happy with this (I assume its something they have already considered, but ought to check), good practice to ensure that the supplies done 'cross over' and feed the same rooms in the building, and to ensure that cables do not share the same cable trays, etc. Suitable notcies to be affixed to new distboards, and those forming part of the existing installation located in adjacent rooms warning as well as within the inside switchroom* of this fact. Careful labeling in the outside switchroom to make it clear that there are two feeds from the public supply and therefore two main switches.
*Existing setup is the supply comes into the outside switchroom, feeds a BS88 panelboard with two circuits, each of the circuits feeds 1busbar chamber in the inside switchroom
Anyone think I've missed anything? would you be happy with this setup?
