jassdhali
At the point of putting the wires to connect everything up - Seplos Mason 280aH with Futronics connector & Sunsynk 5kW Inverter.
I have the Futronics connectors.
The more I read on what size cables I need the more I am getting confused, so please help.
Futronics connector accepts 50mm2 cable but Sunsynk accepts 35mm cable.
What is the best way to connect the 2, a busbar?
Also I need to add an circuit breaker between the 2, I chose:
https://www.amazon.co.uk/gp/product/B09VYLX65Q/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
And for the 240v circuit:
https://www.amazon.co.uk/gp/product/B09VYNBXZY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
As din mounted I was going to place them both near the Inverter for neatness.
I have purchased a 6mm to 50mm crimper also so that I can make my own cables.
Any guidance would be appreciated, or in fact your setup details.
I am taking pictures along the way so will be posting them up, more so in Easter week as I am quite busy with life
Thanks again
Jass
Thanks again
Jass
