graeme mac
Hi all
Can I test 3 phase extention leads using 3 pin plugs with L1,L2,L3 and N looped together?
you must mean 5 pin L1,L2,L3,N,and Earth ,connect them all together for Continuity then remove links to test IR across all 5 pins3 pin plugs with L1,L2,L3 and N looped together
Why would you want to connect them all together for continuity? defo not the way to do it, you want to open both ends first, i.e plug and socket, to make sure the wires are connected correctly and securely. Then test for continuity end to end, L1to L1, L2to L2 L3 to L3,and so on, then IR test between each conductor, connecting them all together for a continuity test will not pick up any problems.you must mean 5 pin L1,L2,L3,N,and Earth ,connect them all together for Continuity then remove links to test IR across all 5 pins
L1-L2
L1-L3
L1- N
L1- E
L2-L3
L2- N
L2- E
L3- N
L3- E
N - E
its important to do continuity first
I was just making a comment about looping them all together and the importance of checking continuity first , you may be getting continuity and polarity confused, that needs to be end to end,and by no way the first test to be carried outWhy would you want to connect them all together for continuity
I understood what you meant, I was afraid that the OP may be confused, if you connected each core end to end, i.e L1 at one end to L2 ,then at other end L2 to L3, and went like that then effectively connected your meter to L1 at one end and earth at the other, then you'd be testing all cores in series, thus proving each core is good, however if you connected all cores in parallel then a continuity test would prove nothing, this is the point I was trying to make.I was just making a comment about looping them all together and the importance of checking continuity first , you may be getting continuity and polarity confused, that needs to be end to end,and by no way the first test to be carried out
