DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Dudells
Opinions please.
Dudells
Morning folks, so Im fitting a new LED emergency bulkhead. 3 cell battery self contained jobbo but when I turn the unit off at the switch I've mounted just below it instantly goes in to emergency mode.
I've switched the supplies (in case I had some how mixed up the switched and unswitched) and its made no difference. Just to double check it I even unpacked and wired in a second unit to be sure and it's doing the exact same.
Share this post
Link to post
steptoe
Its wired wrong
Post up a pic of what wire you have going where,?
Share this post
Link to post
kerching
Exactly what @steptoe said...it's wired wrong
is the switch on the neutral by any chance :C
Share this post
Link to post
Rob_the_rich
Or polarity of whole installation?
Perhaps the batteries are dead and need charging up. It should say in the MIs though.
Share this post
Link to post
Andy™
been on a job before where those higher up and know everything about designing electrical systems insisted on all light switches being DP. despite our objections, they were right and didnt listen, so we wired with DP switches... have you done the same?
Share this post
Link to post
binky
is there a link that needs removing? If battery charge LED goes out when switched off, you haven't got a permanent supply.
Share this post
Link to post
Dudells
Sorry reply chaps had a busy one. It's wired in correctly but I only had one feed going in to the room and it's literally a concrete box so I took 2 cables off the 1 feed and put one through the switch and 1 beneath it going straight through to act as an unswitched live.
I thought this as well but the supply stays powered I had the tester on it to make sure but the LED still goes off and the fitting goes in to emergency.
Share this post
Link to post
binky
Test point turned off?
Share this post
Link to post
Dudells
I wish, that would make sense. I'm back in tomorrow so I'll take you all photos.
Share this post
Link to post
binky
do ypu know what the make and model of the light is?
Share this post
Link to post
steptoe
its not,
it doesnt work correctly,
so therefore its wired wrong,
you either dont have a permanent Live, or its in the wrong terminal, have you mixed up your permanent live and sw live at the fitting.?
Share this post
Link to post
Sharpend
I’ve so missed this direct but polite approach, Andy had a go in your absence, less said the better!!!!! ;)
Share this post
Link to post
Dudells
What's up?
16 minutes ago, steptoe said:
its not,
Not mixed switched and unswitched. As I said further up I had to make a work around for the unswitched
Share this post
Link to post
Sharpend
It’s in reference to our colleague @steptoe
Share this post
Link to post
Dudells
Ah right
Share this post
Link to post
Sharpend
Exactly how have you connected this and what switch are you using?
Is the original supply switched?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
FORUM SPONSORS
Electrical Test Equipment
Test Meter Calibration
Test Equipment Manufacturers
Electrical & Tool Suppliers
Tool Manufacturers
Electrical Software
Green & Renewables
Label Supplies
Education & Training
To Advertise and become a Forum Sponsor of
talk.electricianforum.co.uk, please
contact the Administrator
Here Thank You.
