DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Hacker
High zs reading on a new build beco house
Hacker
Just finished another beco house but a little bigger with vaulted ceilings this one . Cable runs were long but installed more circuits, my socket ring got 0.84 . Was wondering if because the cables are inside an insulated wall would have an effect? And anything that could be done to improve the results? . My next project will be bigger and would like to see more usual readings, anything to be advised on??
Share this post
Link to post
Doc Hudson
High -vs- Usual?  how are you defining these values?  Something is only high if it is out of proportion to the cable lengths involved. e.g. I bought a round of drinks that cost me £25 do you think that is high?  Maybe yes if there was only you and three friends,  but not if it was a group of twelve old school mates?  As you include no specifications of lengths, CSA of conductors etc.. not much anyone can say really. 'Usual' is only 'usual' if it is proportional to the cables lengths, and the tables in BS7671 can give guidance as to expected values for different lengths at various conductor CSA. You can't just expect every job to have the same values.
Share this post
Link to post
kerching
Surely if this is a large property then the issue of long cable runs would have been flagged up and addressed at the design stage?
resulting in, amongst other things, installation of one or more sub mains feeding local boards, larger cable sizes etc
socket ring got 0.84....what does the design project the results to be
is this R1 + R2, r1+r2, etc etc etc
what is Ze
also 'cables in Insulated wall'......for what length?, thickness of insulation?     How much have they been de rated?  ( 4mm in 0.5m of insulation > 100mm is ( off the top of my head) only good for 16A
as for the insulation effecting the resistance, well.........
Share this post
Link to post
Andy™
is your Zs off fom your cable design calculations? what about R1R2? higher than expected or not?
Edited by Andy™
Share this post
Link to post
Murdoch
What were the end to end readings? What is the Ze?
Share this post
Link to post
Bruspark
Do the readings differ from your design calculations ?
.... Or is this a silly question
Share this post
Link to post
Adrian
My worry would be the installation method
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
