DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Lacer75
4th wire confusion
Lacer75
Is anyone able to tell me what the forth wire on a light is please. I know live, neutral and earth but not sure where a 4th wire should be connected. So any help would be appreciated.
Share this post
Link to post
Sharpend
Which light?
Share this post
Link to post
Lacer75
I can't seem to attach a photo unless you can tell me how then I'm happy to post it to help
Share this post
Link to post
Rob.
Until you have posted 10 times, or a moderator approves you. Then you can't post photos.
Share this post
Link to post
Sharpend
Can’t quite make our colour, but I suspect that is an earth that carries down the fitting? What colour is the core?
Share this post
Link to post
Lacer75
Thanks for your help. It's a silver wire with a streak of green through it. If it is the earth through the light would I just wire that into the earth on the ceiling rose?
Share this post
Link to post
Rob.
Yes, but I would want to prove it is an earth. Otherwise, it'll go bang.
Got any test equipment?
Share this post
Link to post
Lacer75
I got an ac detector for behind walls but nothing else. Any way else I could test?
Share this post
Link to post
Rob.
9V battery, a length of wire and a spare car headlamp.
Share this post
Link to post
Evans Electric
I can make out a brown stripe  ..a blue stripe  and the Gn/yell ,  as Rob says , get a 9V  battery  & car lamp & complete the circuit down that extra wire and back from the body of the fitting  , which we'd assume was metal .     Can't think what else it could be but strange things happen .
Share this post
Link to post
ProDave
That fitting has TWO earth wires.  The silver one with a green thread goes down to earth the bit on the bottom of the pendant, and the short green / yellow earths the bit that is screwed to the ceiling.  BOTH must be connected to the earth of the cable feeding the light.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
