hi guys - first timer here so please go gently!
I have just bought a new light fitting which the connection wiring is already in a set block and all that’s required to do is put ‘N’, ‘L’ & ‘E’ cables from the ceiling rose and off i go.
However as the wiring is on a loop the question I have, is that do I remove the Earth from the ceiling rose and put into the block, or do I leave the block with just N & L as the loop
will Do the same thing!
as you’ll probably already know - I’m not an electrician or have any experience about wiring loops.
thanks
thanks
