DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
shower tripping RCD
Guest Dane
Question
not sure if i am over looking something with this one
Everything tests good, insulation resistance is good... every things fine with testing.
apart from it trips the RCD
Connections are all tight, wondering if the showers foobared?
any suggestions?
Link to comment
17 answers to this question
Does it trip immediatly, after a certain time or random?
if its after a certain time, it may be that shower element is faulty, but not switched on until shower is in use, which will give you a good IR. maybe take cover off and IR on the terminals to heater.
Link to comment
strange one really..
It didnt trip the first time it was used.
The second time it tripped, it was fine with isolator on, then tripped when shower came on
and now, it trips as soon as isolator is switched on.
Link to comment
is that with shower switch (on the shower) turned to 'on' or 'off'?
Link to comment
first time was fine
second time the RCD tripped after about 2 minutes of use with the shower.
and now it just trips as soon isolator is "on" and shower switched off
but then the shower will run and no trip.
IR is >1K aswell
Link to comment
possibly an intermittent fault. water may be getting somewhere in the heater it shouldnt. and >1K isnt much for IR. it should be much higher. 1K is actually .23A at 230V! more than enough to trip a 100mA RCD
Link to comment
check that water is not getting into the shower when you are using it
that just sounds wrong....
Link to comment
meter shows >1000
The shower is bone dry inside. i checked that strait away, ive checked everything really. im just wondering if any one can sugest anything else.
apart from replace the shower.
btw this is not my shower so trips to and from customer haha... twice and they wernt in when arranged!
Link to comment
meter shows >1000
>1000 what? if its IR, its most likely M, not K
Link to comment
yes sorry its >1000 M
i meant K as in 1000 ... late at night.. long days taking there tole, and a women laughin her head off reading a book!headbang
Link to comment
where did you measure this >1000M?
Link to comment
new to fault finding properly, normally get easy things lol. this is probably easy but me been daft
i have checked all runs of cable. CU to isolator, isolator to shower, then CU to shower with isolator in "on" position. L - N L - E N - E all >1000M
the RCD is fine, as i threw the shower onto the other side (dual RCD) and it tripped that one also.
Link to comment
or even a 30 mA RCD..............or probably a 300mA RCD for that matter. :D
Link to comment
shower has been there a while..
connections i have checked over twice.
off back there tonight after a long day on site so see what else i fine :)
Link to comment
Archived
  • Create New...
