There is a lock fitted, it's locked in the on position.why would you not be able to reset, as there are no locks fitted, still looks wrong
There is NO lock fitted. I have fitted a few of those Proteus units, one of the few good items they have. The yellow 'clip' is just that, a clip & the lock out clamp does have a screw to tighten it to any breaker and then a padlock would be put through the hole. The screw may not be tightened up and just sitting there like i have done.There is a lock fitted, it's locked in the on position.
If it trips, to reset it, you would have to switch it to the off position then back on.
I was referring to the metal thing on the mcb.There is NO lock fitted. I have fitted a few of those Proteus units, one of the few good items they have. The yellow 'clip' is just that, a clip & the lock out clamp does have a screw to tighten it to any breaker and then a padlock would be put through the hole. The screw may not be tightened up and just sitting there like i have done.
