Hi, Can anyone suggest what type of fan i will need for the following, grill or fan on ceiling, then fed to flat chanel down the wall, approx 2.5m then 4.5m solid round duct to external vent. (plenty of fall on the round duct)
Cheers
Cheers
how small?It's for a small ensuite with a shower, it has been purpose built in a downstairs room for a disabled chap.
Cheers
Air changes per hour is usually specified in the building regs. It's the number of times each our the fan is replacing the volume of air in the room.Sorry steps, Size is approx 2m x 1.5m. I'm not sure what air changes are?
Cheers
I that's an issue, Vent Axia do a heat recovery individual fan.Also remember that your client has to heat the air in the room the same number of times as the air is changed, this can turn out to be expensive!
Building regulations apply equally to a new build an an alteration.Do the same rules apply with an existing property the same as a new build.
