- Jul 8, 2010
- 373
- 0
well guys, my niceic assessment is next week. and the nerves are settling in .. only reason im nervous is, i havent actually started much work in the way of domestic electrical as i wated to achieve niceic status first (loads of work booked in though) .
anyway just a few queries,
after a consumer unit change which im being assessed on i have done the relevant testing and filled certificate out (will post pics as soon as i find where ive misplaced my camera), now i had a friend with me when i done these tests who has said that he would turn the main switch off on consumer unit, and also go outside to where my isolator switch is , in cupboard with meter and turn that of awell. is this the correct way or can i just turn the main consumer unit switch of and continue my dead tests? minds starting to go blank with all the revision ive been doing, been some length of timne since i finished all courses etc so need some refreshing . maybe a silly question however better to check than be caught out on assessment.
2nd of all, i have purchased the cal card ext 1, which i use for the couple of tests to prove calibration of my megger, but i know ive got to test more to prove to niceic? also know i have to prove consumer unit is live before isolating, but cant use megger and cant use multi meter, whats the easiest way?
last but not least i have today been to look at a family members job which has been done by a part p electrician , he had a consumer unit replaced and the property has an earth rod installed.
the consumer unit is in a cupboard outside the property, with the rod directly in the ground below this cupboard. however the earth wire from the rod to cupboard has no protection and is simply clipped to the wall, is this ok? my feelings are it should be ran in some form of conduit but thought i would check.
cheers for replies in advance
