RCD Trips when lights switch off
ipd1961
Feb 3, 2010
5
Hi All
Just a quick one,got a problem I have never come across before. When I switch off a recently wired outside light the RCD trips, it doesn't happen when you switch it on only when you turn it off. There is no water ingress and no sign of tracking (these would surely both cause RCD to trip when turned on). Any help would be greatly appreciated
Thanks in anticipation
Hi AllJust a quick one,got a problem I have never come across before. When I switch off a recently wired outside light the RCD trips, it doesn't happen when you switch it on only when you turn it off. There is no water ingress and no sign of tracking (these would surely both cause RCD to trip when turned on). Any help would be greatly appreciated
It would trip when switch off if some plonker had stuck the earth wire into the unused half of a 2-way switch?
Can you reset the RCD while the switch is OFF?
i.e
is the fault during the instant of switch off
OR
permanent while the switch in the off position?
:| :innocent
Is the switch double pole?
Have had problem with double pole switched sockets tripping when switching OFF.
Is the switch double pole?Have had problem with double pole switched sockets tripping when switching OFF.
You are thinking around the blue sky, envelope, outside the box there timmyspark....
You obviously need more...
GuinnessGuinnessGuinnessGuinnessGuinness
at this time of night!
Spose could be switched fuse spur with neon and something lose inside?
You are thinking around the blue sky, envelope, outside the box there timmyspark....You obviously need more...
Straight up
Do a bit of research and you will find its a known cause
Thanks for all suggestions,
Firstly its a one way switch wired three plate
Secondly the earths are all nice and tight in their terminal
Thirdly the RCD can be reset with the light switched on or off
All wiring was new last year and tested (results were ok)
All connections have been checked and tightened and nothing untoward has been found
Losing whats left of my hair
bad day explode
